Ben wrote:Nice, so you can now control whether you have FWD at all? i.e tell the car it's pure RWD and not to bring in the fronts?
Well I can do that at the moment as have a switch to disable the FWD
but the idea of this is that it also allows you to control the 4wd seperately, with one controller for 4wd application during cornering and one for acceleration/decelleration.
This will be great in the wet as it will enable me to dial more 4wd for cornering, which I can then stop before the point of creating understeer, while maxing 4wd on the straights, thus maximising traction. Which is good, as the GTR is a bit of handful on a wet circuit. Last time out at snett there was no point in even running in the pm on the sodden track.
