This tremendous 360 photo by Matt Woods shows the unit as it used to be!!! The dyno cell is moving as part of APT's business expansion, so the mezzanine and storage needs to come down, with all of the Evo panels, subframes and other bits being stored safely and securely in the mean time
The dyno cell will be moving next door into a purpose built extension and in its place will be an all singing and dancing alignment set up, so APT will be a truly one stop shop for everything from engine builds, chassis alignment, super-safe tyre fitting and just about everything else too.
The mezzanine is about 50% down now, with the remaining floor to be taken up before I take a 14lb hammer to the wall and blockwork
So tomorrow's plan is to remove the rest of the flooring and timber bracing from the mezzanine, get Gary to sort the electrics and then the old dyno cell will be no more. Things are moving on very quickly at APT HQ and the future is looking very bright indeed
Very best of luck to the APT team; I'm sure your business will go from strength to strength.
*More pics tomorrow with updates from the guys.
