It is if the engine codes are the same... For example bam and amk engines run the same
All vag dealers use TPS so he will get you a good price hopefully, if not I'm sure Gary will have a trade account with them
Also what reader/scanner do you have as it might not show up miss fires
Henry......
No, been at work all day:(
It coughed and farted so badly this morning (2 deg outside) it nearly stalled, but after about a minute, ran spot on all the way in (7 miles, mixed roads and between 5mph in traffic and 60mph on dual carriageway) to work. Spoke with Dave J about all manner of things, but when we spoke about the car, he mentioned that some cars need the cold start activating by switching ignition on to stage 1 (lights up) depress throttle to floor once then up, then start the car.
I did this and it ran fine all the way home.
Cupra.net (sometimes a hostile place, but some good people on there) pondered if the fuel pressure regulator might be shot, or the fuel pump? I've no idea about these at all!
Definitely fine under boost, so maybe I'll drive it everywhere under boost!!
If in doubt, flat out
Well as usual with my cars, it did nt misbehave at Dave's even though it had been left over night. The only code was something suggesting that there was a pressure issue between the turbo and a vaccum pipe (or something else technical) but the considered opinion was that it was due to over fuelling from cold. I have spoken to the "map man" about having it reverted back to a standard map. He reckoned it could the the EGR, but having run it with it disconnected this morning, it's not the EGR. I get it set back to normal, and see how things go.
The will be up for sale shortly, either as a daily, or as spares or repairs. It's a shame, but things have changed with finances too much to permit me keeping. If someone wants a cheap doner, give me a shout.
