Mk3 Golf track project.
Pike
Post by Pike »
Looks like you've had a busy weekend!
You can lose the dash bar without sacrificing any rigidity in the shell.
The strength between the A-pillars comes from the firewall and the "lip" under the windscreen.
When you go strut brace shopping avoid the rear type that bolt onto the top of the damper shafts. They do nothing but put bending loads through the damper shafts that they aren't designed to cope with.
The front upper brace makes some notable difference and removes a little mid-corner camber change through corners like Coram when there are considerable loads being transmitted through the shell.
2008: VW1 3rd in Class
2009: VW1 3rd in Class
2011: Ginetta Challenge
jazzymonkey
Post by jazzymonkey »
Thanks Pike, I thought I needed to keep the dash bar.
Now I need some bracketry to secure the steering column with the bar removed and some answers on how to mount the dash clocks.
Ian200sx
Post by Ian200sx »
we just drew a line and cut the dash at its last bracket which left the clocks and steering standard which was real easy
mk1 escort, supercharged.
jazzymonkey
Ahhhhhh, nice idea. Have you got any closer pics? Where did you get your rear strut brace?
Ian200sx
Post by Ian200sx »
Thats the only pic I have,but you maybe able to zoom in? strut brace was home made
jazzymonkey
Is this a current project Ian?
pjs65
Post by pjs65 »
Makes me smile about cutting the dash in half with a grinder , drastic but effective . Pete
Ian200sx
Post by Ian200sx »
It is a current project that i part own with a friend, we both have other projects on the go but the golf has never let us down yet! Got some slicks last year for it so it will be worked on soon. A garage is being built that will allow more work to be done
jazzymonkey
Is there any threads on here about it? I would be keen to know what you've done and the results of your labour.
Ian200sx
Post by Ian200sx »
