Looks like you've had a busy weekend!
You can lose the dash bar without sacrificing any rigidity in the shell.
The strength between the A-pillars comes from the firewall and the "lip" under the windscreen.
When you go strut brace shopping avoid the rear type that bolt onto the top of the damper shafts. They do nothing but put bending loads through the damper shafts that they aren't designed to cope with.
The front upper brace makes some notable difference and removes a little mid-corner camber change through corners like Coram when there are considerable loads being transmitted through the shell.
Mk3 Golf track project.
