My SWB TT Z32...
- jap.slapper
Monster wrote:Ah, just read the spec properly, I think I've got some slicks so will check the sizes and let you know. I've got some spanking new hoosiers that I bought for mine but they might be a bit wide for a 10" rear, I ran 11" and from memory they're 305 wide but again will check
Cheers chief
I reckon I'll be good for getting it on track mid June so will give you a shout mate if yours is good to go
- jap.slapper
Well tomorrow will be the zeds first time off the drive in quite a while....so fingers crossed (good start I've just had to put the battery on charge!)
- jap.slapper
- jap.slapper
I've just had a quick flick back through your GTR build thread mate, now I was thinking about drilling some holes (I don't think that I need to do any more with the front bumper) but possibly the rear could benefit from similar holes being drilled in the rear bumper to try to eliminate some of the drag effect.
Would there be any point in doing this chief?
Looks cool
Saves weight
Helps cooling
Reduces drag
Makes pretty plumes of smoke on drifto
Saves weight
Helps cooling
Reduces drag
- jap.slapper
You should read my old M3 thread
That was immense fun building, maintaining and ragging the arse off of that thing for peanuts............
It's all about value for money.
