A nice gloss roller and you'll be set
Its well cool and i have sat in the chevy and done some imaginary cornering with it , i will admit to that . Not really looking forward to doing up them flywheel bolts because the heads arent that thick and 80ft/lb is quite a bit to drag on , i will have to physic myself up for that .Rob S wrote:That Nardi wheel looks lovely, what a complete bargain.
Don't envy you with the clutch either, you'll need your spinach for that
The clutch is the size chevy used on its big blocks and i got it because having done the axle and now the gearbox the Camaros good to handle a 500hp + motor:hurray:. Pete:Chevy_anim:Stuart wrote:Nice stuff Pete. The clutch will earn its keep I think, with all of that engines toque to contain. I liked the little fabrication job, and like many of your kind, you make it all sound so easy
Keep us posted.
