Hi Mike, Duncan Graham at Racedynamics he has a link on BP he did an excellent job taking great care to set the car up exactly as I wanted it. If you cant find his link give me a PM and I will try to find it on my other PC.Mikey,S wrote:Harry where did you take your ECU to get it looked at .....I reckon i,ve got a problem with the Apexi I had fitted .....it shuts the Idle Valve off.....m
I think a Baffle Plate is now a must as I am able to get much higher forces in corners than when I first started out with the car.
Harry
