Do you know how to get CD's out of the headunit!! (the multi-changer in the dash) I get an error code suggesting that on is still stuck in there.
It's a real common problem unfortunately. You can try removing the head unit and unplugging it for 5 minutes then plugging it back in. Every now and then it used to work otherwise we just sent them off to get refurbed. I think they are a Pioneer or Panasonic unit so a local car audio should be able to fix it for you.stuart wrote:Thanks Jon
