The Integra...
drifter
Post by drifter »
Tonynos wrote:I had those gauges in the Scooby. They looked really good but the oil pressure gauge went tits up after about a year and the alarm function that can not be turned off gets on your nerves after a while :frown:
I hope you have more luck with them than I did.
The alarm can be turned off, hold the button in when you turn the ignition on :) I had the same gauges, oil temp was a bit off, so I replaced them with STACK :)
I ran the DC2 at a few events and did some serious laps back to back. I never experienced any problems, although I had no gauges either. I would say that you'd be fine but maybe speak to Johnnie Becker @ Bentley? He is the Honda/Bentley Master Technician who happens to be the son of ex-Lotus Director Roger and brother to senior Lotus test driver Matt. He is also the guy that bought my DC2 a few years back and what he don't know about Hondas...............
Let me know if you need his number.
Safety_James
More Goodies Arrived Today.....
Post by Safety_James »
The joys of working at a race circuit... things get delivered by participants :sifone:
Tein super streets with 1200 miles on them, bit of a bargain so I'm pleased. :coolgleamA:
Started to clean up one of them, will do the rest this afternoon and they shall be fitted tomorrow.
She's getting there..
インテグラ TYPE R 無限
Most excellent :)
Safety_James
Well went to sort the gauges out, and like some of you said, they could prove problems, both of them were kfunked :banghead:!!
Neither worked at all.. Obviously something inside them decided to not work, so they are on the way back to wherever they came from, and have ordered a totally different set. :(
Coilovers are on and sorted, the rears were seized but with an amazingly quick turn around they were re-conditioned and what a transformation!! Handles like a dream!! Really chuffed :smash:
Have got lots of different extended hub bolts to try out this week for the best fit, so i can safely run the 5mm spacers needed to clear the calipers, and some new whizzy open ended lightweight nuts :D
You win some you lose some hey!!
インテグラ TYPE R 無限
James, seeing your car develope further and further is seriously annoying me :D i want my coliovers! :)
but on a serious note, things are really shaping up nicely :D
Not a bad ratio 3 good bits : 1 bad :)
Shame about the guages.
bennyboy
Post by bennyboy »
James you should have got Auto Gauge.. they're performance meters No.1 !! :cool:
i had an auto gauge rev counter in the mini ^ absolutley fantastic :thumbs:
Safety_James
Just got some simple ones through a bloke at work, see where i get with those. Failing that ill look at Autogage. !!
インテグラ TYPE R 無限
