Well went to sort the gauges out, and like some of you said, they could prove problems, both of them were kfunked
Neither worked at all.. Obviously something inside them decided to not work, so they are on the way back to wherever they came from, and have ordered a totally different set.
Coilovers are on and sorted, the rears were seized but with an amazingly quick turn around they were re-conditioned and what a transformation!! Handles like a dream!! Really chuffed
Have got lots of different extended hub bolts to try out this week for the best fit, so i can safely run the 5mm spacers needed to clear the calipers, and some new whizzy open ended lightweight nuts
You win some you lose some hey!!
