yeah should be a right laugh when the cars done
plus ill get to meet you too
that sounds okay then if adrian/bazza said it would be the same, i spoke to lou + barry sheldrick about it and they said a standard lid would be okay too. but to double check heres a shot of the sticker on mine;
so that means im okay as you quoted BS6658 Type A ( blue & white BSI sticker) is one of the ones i need
again lou and barry recommended the fx300 for me and fiar play to them they said thats it overspec'd for my car but it will put up with alot of abuse, so i'm seeing both sides and benifits of the fx300 and standard toyota clutch. but what will be best for me considering im planning a fair bit of track time next year aswell as road miles too? (about 12k) im guessing what russ says will be better having a standard unit, because mines lasted 140k and still going as long as you dont slam it in gears
also i know of some benifits of a lightened flywheel, but would say a cheap 'stage 1' if you will flywheel yeild many benifits for the 2?
ive noticed with my new system and intake how much more lively the car feels with response and sudden power through the range, its brilliant. but even with my 3S-GE like your 3S-FE theres only so much you can get from it without spending a fortune or swapping units.
thanks for the advice offer, one thing i'm still not sure on though, do i need to buy fireproofs, or can i (like trackdays) get away with long sleeves and jeans?
thanks for the advice guys
