golf vr6 track toy
Ian200sx
Post by Ian200sx »
with the stock brakes, ds2500 and fancy disc they were still cooked at snet hence trying these brakes. Lloyds tried a few brake combo's on his vr6 and for the money we thought the new ones should help.
what seats are you using? side mounts?ours are base mount and we got away with the stock frames and even kept the height adjustment. the stock frames really are easy to mod for some seats
mk1 escort, supercharged.
ginger ninja
Post by ginger ninja »
Ian200sx wrote:with the stock brakes, ds2500 and fancy disc they were still cooked at snet hence trying these brakes. Lloyds tried a few brake combo's on his vr6 and for the money we thought the new ones should help.
Interesting about the brakes..will have to keep an eye on them, even with my novice track knowlege I cooked the brakes on the Vectra at Snetty.
I have got a side mount seat with the brackets but looking at the subframe I think a little bit of fabrication I should be able to fit it and keep the height roughly the same plus it will be nice to keep the back and forth adjuster.
Julian.
This looks like a fun project any updates as to how the brakes are working out for you?
Ian200sx
Post by Ian200sx »
not had time or money to go test the brakes yet. hope to get out on track this month though. lloyd get married in 240 ish hours so "isn't aloud out" with the golf at the moment ether
lolek
Post by lolek »
marrige over with and ive been given back half a bollock back, so hopefully we'll get the car to the drag night and blow the cobwebs out of it. permission granted that is ;-)
You still going Wednesday? Be good to see it in the flesh (Might nick some ideas for my Golf)
Ian200sx
Post by Ian200sx »
After a few track days the brakes have held up well.and the golf has generally been good. Next stage has been taking out a bit more weight. Home built rear strut brace
wrapped tubular manifold, which was a pain to fit
oil cooler as we'd been seeing over 120c often so hope this will fix it, new bucket seats as the last one was a bit wide for me.
and one of my most pointless blue peter moments
Stop tinkering..................you'll get me started with mine!!
nice work :smash: as for the abs, just remove the fuse for it ;)
Ian200sx
Post by Ian200sx »
the fuse doesn't weigh much! every little helps.
