bmw e36 track project
antonioo
Post by antonioo »
nice work on bmw 8) 8) :grin: :)
just a random fact for you i had the exhaust system off today to do some jobs and i decided to weigh it .........
32 kgs :o :o that does not include the manifolds.
jason
Nik
Post by Nik »
That's quite a bit of weight you could save Jase. :D
Well after our trip to Spa gave the trackday budget a hiding and the fact that work has not been very good this year the car has been hanging around on the ramp most of the time gathering dust .
Before the track eve i got a carried away with the exhaust and removed the cats and some small silencer boxes which left me with a static noise test of 102db ,oops. I have also fitted a light weight flywheel coupled with an M3 clutch along with a modified ecu which has raised my rev limit by a 1000 rpm.
To address the noise issue on a budget i purchased some of this;
had a rummage around in the workshop and found some of this;
made some of these;
now all i have to do is stick them all together . also eddy pointed out that the larger tail pipes could be removed and smaller ones fitted to help but i think i will utilise the larger pipe and make them into tail silencers with the perforated pipe i have.
I managed to find some 17" rims to use which are 8 1/2" so i fitted the tyres today and offered them up on the car ,a bit more negative camber will be going on front and rear .snug is a good way to descibe them .
ill get more pics up as i go Rockingham is only 3 weeks away :driving:
Those 17" alloys look superb and should give you a fair bit more grip. Hopefully the exhaust will do the job; what's the decibel limit at Rockingham?
Back to the project, did you notice any difference with the flywheel and clutch? I've only track driven my E36 and that already has a 5kg one in there.........I suppose it should help with reciprocal masses?
I'm not sure on the noise limit is at rockingham but its no worse than snet .
the flywheel seemed to let i rev quicker without getting bogged down if you see what i mean . :)
new wheels painted . some arch mods will be required on the rear over the winter i feel ;)
:auto:
That is such a nice car, can't believe I still haven't seen it in the flesh or metal yet:)
BIGBIMMA
Post by BIGBIMMA »
thats looking very nice jase , dont think you will need to worry about straight line speed with the amount of corner speed you will be carrying now .
Very tasteful Jase. Love the white wheels. :D
