What does primed mean? It means 'filled'blacky wrote:But a oil cooler core is not like a radiator in your house Gerry! Its not just a big emply space. I reckon once primed there would be no air in it.
So you're correct
You can't apply fitment constraints. What's the point of fitting something that's not efficient? You may as well fit a smaller cooler, that fits, but will work to it's efficiency. If it's the right size but doesn't fit, move it to somewhere where it does fit, or re-arrange what's in the way.blacky wrote: Depends on fitment contraints tho doesn't it. Thats why mine was fitted that way. Also a couple of the kits come so they fit like mine as well. Can't remember their names but some of the expensive ones.
For a difinitive answer I'll ask one of the technical guys here at work....
