Camber on classic STI Scooby
Andy916
Post by Andy916 »
Camskill for camber bolts, and their normal price is about the same as the GB price :thumb:
stockcar
Post by stockcar »
as is our price................
ASPerformance
MOTUL & MILLERS OILS,
online shop!!
BentMetal
Post by BentMetal »
Here's another pic I found taken at the Ring last weekend. This is on my current set up. As you can see, lots of tyre killing bodyroll!!!
Image[/img]
Fast Eddy
Post by Fast Eddy »
How about some progressive poly bump stops as a temporary or even permanent measure.
I have these in stock at just
BentMetal
Post by BentMetal »
Just thought I'd put an update on here regarding my quest for handling nirvana :D
I've tried a few things suggested in this thread and have now settled on 2 degrees front camber, 1.75 rear - adjustable top mounts were not required.
I've gone for a small amount of toe out on the front, put the rear roll bar on it's stiffest setting, moved the rear damping to position 10 of 12, backed the front off to the middle damping and added a whiteline front roll bar to reduce front roll :wave:
And the results were.....................
BentMetal
Post by BentMetal »
It's much improved :D
As a compromise between road and track I think this is very good.
For pure track use I think it could do with another degree of camber and higher spring rates all round but I think I'll leave it as it is for the time being :wink:
