Is it under warranty?!
Rover tomcat-updated
yep checked it , disconnected the feed into a container, doesn't run down in the turbo though oil just sits there even with the drain disconnected.pablo wrote:Might be a silly question but is oil getting to the turbo through the oil feed, assuming it's oil cooled :?
Stripped it down last night - wheels look ok but it you try to spin the wheel with it on it end it locks up and there is some end float, suspectbearing has broken up, the actuator was adjusted very short when I recieved it so I guess it had been running high boost!
Was told though that it was all ok and only done 8k
new intercooler fitted
Just fitted new intercooler replacing my blown pulsar one..and also front mount oil cooler
Just about fitted in!
