1989 Celica GT-Four - Update:April 2008 Rebuild commences
andycaca
Post by andycaca »
ill be at barkston next sunday, without fail. however i will be driving the peugeot :)
the wheel has been sorted, should be here soon!
andycaca
Post by andycaca »
well, ive finished soldering the ecu connectors and plugged the motec in. the car cranks but i cannot communicate with the ecu via the RS232 cable. no matter what i try it just ignores me.
bastard.
back to the drawing board tomorrow with crocodile clips and soldering iron. lets just hope this isnt a duff ecu...
Try to perservere Andy. These bloody cars always try and trip you up, regardless it seems.
Just keep thinking of the spanking you can give the car when it is done. Will make it all worth while :D
gary@apt
Post by gary@apt »
andy what motec is it theres a couple of ways of connecting for rs232...
andycaca
Post by andycaca »
gary, its an M4 and ive checked the wiring on the PCB itself (RS232 port wired directly off it). the guy i bought it off said it needs the older M4 software to communicate so i will be trying that tomorrow (downloaded about 8 old versions to try).
the serial port is definitely connected 100% as per manual specs...
andycaca
Post by andycaca »
its alive!
the ecu that is, not the car as a whole. there must be a problem in the car wiring as ive hooked the ecu up to a battery and its working fine.
i wasnt sure of this when i bought it, but its the Pro version with all the advanced tuning features enabled too...things like:-
higher resolution tables
wideband lambda control
launch and traction control
anti lag :D
512k of data logging
and probably other stuff too :)
andycaca
Post by andycaca »
and the car runs :)
thanks to adrian at fensport for building me a map :)
andycaca
Post by andycaca »
lastnight i got told off by the farmer for antilagging/launch controlling the car around the yard.
oops :D
andycaca wrote:lastnight i got told off by the farmer for antilagging/launch controlling the car around the yard.
oops :D
Class :D
alwayzsidewayz
Post by alwayzsidewayz »
Only you Andy!! lol
Celica GT4 ST165 Modified used in the 2008 Toyota sprint series
Car no 22, lots of fun, answers to the name Trinity
