Need to contact John Sharp at B19 I'll PM his number if you need it.
What are you setting up on the rollers? Nothing's adjustable.
Can sort you with a Detalarm too, if you want one. Smaller & cheaper than Knocklink, once I get my act together :oops:
jisc registration
Your ecu controls fuel & timing and yours is non adjustable.
Fuel could be if you have an adjustable fuel pressure regulator, otherwise it's also fixed by the OE reg. You can check for det with cans or your CEL light flashes if any is detected by the sensor.
I don't think that's all cr@p but if someone knows better .........
Gerry H wrote:Your ecu controls fuel & timing and yours is non adjustable.
