Sounds like you've got off pretty well considering..
As Bubble says MOT garages have problems when police officers issue these forms as this is not what the Vehicle Defect Rectification Scheme was intended for.. It was intended for wear and tear items (tyres, windscreens, exhausts, lights, etc) if found to be defective when you were stopped, you could get them fixed and checked at an MOT garage and then the money would go back into your car in lieu of prosecution.
If the car is modified illegally (window tints, numberplates, lights) then they recommend prosecution in way of a ticket or report for summons, however the officer still has his right of discrection and can warn you about it!
It seems that you were stopped by a fair cop and he's given you the option of getting the work changed and checked, which you've done so there should be no futher problems! If however you were to be stopped by him again then he'd probably throw the book at you for not listening to his advice.
The numberplate offence would of been
calling any police officers on here
from what you said, he sounds to of been very fair.
all sorted now.
still make me mad abit, as have had the tints on the car when i brought it, they must of been fitted by a older owner. i have owned the car for nearly 2 years and nothing has been said before, mayb i have been lucky??
Can you pm me 6 different numbers from 1 to 49 please. ??
just finished work so my brain has giving up lol
all sorted now.
12.29 @ 110.6 santa pod
the scoob is a JDM hoe
Here is a usefull link to the number plate regulations http://www.dvla.gov.uk/media/pdf/leafle ... plates.pdf
I keep a printed copy of these in the glovebox, because as mine is an "import" it can have smaller number plates
Geoff Boston R34GTT RB30
__________________________
