this afternoon i have been mostly.... fitting a wideband
Despite me getting carried away with myself recently and amending my ecu maps pretty much wholesale I had been doing that without a wideband :o
Anyway I got hold of a Innovate LC-1 which arrived today and proceeded to fit it today. (sorry Gary)
This is supposed to be a permanent install but I thought it would be more flexible if I treated it like a semi permanent install and soldered a cigar lighter adaptor to the ends. Properly fed through the bulkhead and tidied away under the footwell this plugs in and I can now map/log away in full knowledge of AFR.
Weirdly enough the target afr's were not too far from the actual once I had road tested it (high 10's) - on the rich side but better to be safe than sorry :D
Getting very confident there Dunk. It was not that long ago you couldn't do an oil change without turning the workshop into the Exxon Valdez
rolty
Post by rolty »
Well done dunk, look forward to seeing it at the meet.
:pmsl: @ Stu
stuartstaples wrote:Getting very confident there Dunk. It was not that long ago you couldn't do an oil change without turning the workshop into the Exxon Valdez
fpmsl
best yet :pmsl:
Err....where are the pics Dunk ?!!!!!!!?
Rich....you wanna stand being my car lol
Been tweaking the map this morning and now running a nice safe 11.1-11.2:1 on WOT runs up to redline :D
God, I am sad but it is really good fun. None of this getting your hands dirty malarky to tune an engine :lol:
mike-payne
Re: this afternoon i have been mostly.... fitting a wideband
Post by mike-payne »
dynamix wrote:This is supposed to be a permanent install but I thought it would be more flexible if I treated it like a semi permanent install and soldered a cigar lighter adaptor to the ends. Properly fed through the bulkhead and tidied away under the footwell this plugs in and I can now map/log away in full knowledge of AFR.
Duncan, i thought the WB Lamda sensor had to have power at all times or it would fail???
you are right Mike.
This will be plugged into the cigar lighter at all times when the sensor is in there.
frayz
Post by frayz »
Why not just leave it in all the time Dunc?
It probably will stay for a while but it is a shed load of wiring and once I have a selection of maps all tried and tested I dont see a need for it in there unless changing them.
