the best tip i can give is give yourself a lap or two to warm the tyres up and get used to the kart. as sdminus says you need to keep your momentum up so dont jump on the brakes too often, you'll be surprised just how wide you can run and still keep up some decent speed!!
also for the first bend after a couple of laps ul be able to bleed off the throttle then put ur foot down before the apex and carry speed all down the next straight and do the same on the next set of corners, the long left hand is flat out and you can overtake on either the inside or the outside!
sdminus there is no way you could have set a 42.5second lap around ellough with that new hairpin section in!?!
my best time was a 54.55 and a high majority of my other laptimes were in the 55's which i thought was good for a first time at the circuit!
Ellough Park Raceway
rayman gtir
42.5 sec's bud..
here is a table from round 1 last month. each dirvers fastest lap in that race is displayed on the far right colum. i started in last place
42.8 in that heat
here is a break down of heat 2 where i spun out.
told ya. pro karts are nothing compared to propper karts and a good driver
Scott
42.8 in that heat
Scott
Hurrah Ben it is today !!!!!!!!murano3 wrote:I'm racing there tomorrow night - way hey
Cheers for all the tips chaps !
Scott that is mighty impressive !!!!
Guessing though the karts that we will use arent a patch on your monster one ! That must be lightning quick !!!!
