S13 or S14 turbo
Need something? ...ask here.
yes standard on the pulsar good for 340/350 apparently
323ian
Post by 323ian »
Gary do you know if this pulsar turbo will fit mate?
drifter
Post by drifter »
The GTiR turbo is pretty much a straight fit to an S14, but it has the same hole pattern as the S13 T25 for the turbo elbow. Therefore if the S13/4 turbos fit, the GTiR should fit. You may have to rotate the core and bodge together a bracket for the actuator. It has a 360 thrust bearing as opposed to the T28 found on the S14 which has a 270deg bearing iirc.
I'm sure Gary will correct me if I'm wrong :)
ants13
Post by ants13 »
think the gtir turbo has a bigger compressor wheel as well.
again, not sure on that though
drifter
Post by drifter »
Yeah it is slightly bigger I think, general opinion is that it can achieve 320bhp on the S14 SR20 :)
drifter
Post by drifter »
Little bit of info on tuning the S12....
http://www.nissansilvia.co.uk/vbb/showthread.php?t=463
Hugh Janus
Post by Hugh Janus »
i have a Turbo from an S13 (T25) sitting here if its of any use, not entirely sure of the condition other than its "used" and as far as i can remember there is little or no play
323ian
Post by 323ian »
Thanks for your help drifter.
Hugh Janus how much do you want for the turbo mate?
Safety_James
Post by Safety_James »
il have standard t28 next satuday if it helps.
インテグラ TYPE R 無限
Hugh Janus
you can have it its just taking up space in the garage, would rather see it get used other than not at all
