S13 or S14 turbo
The GTiR turbo is pretty much a straight fit to an S14, but it has the same hole pattern as the S13 T25 for the turbo elbow. Therefore if the S13/4 turbos fit, the GTiR should fit. You may have to rotate the core and bodge together a bracket for the actuator. It has a 360 thrust bearing as opposed to the T28 found on the S14 which has a 270deg bearing iirc.
I'm sure Gary will correct me if I'm wrong
- Safety_James
