With the headlight removed there were a few bits of wiring that needed tidying out of the way so they wouldn,t obstruct the airflow to my filters.
The new vent fitted extremely well, no trimming necessary :-D The old wiring for the original headlight was unpluged and put out the way for ease of use when and if i need to refit it.
The new vent used the same bolt holes as the original headlight so was pretty easy to fit. The light in the new vent works on full beam with the original wiring plugging straight in
Just to finish off, i added my bigpower sticker from my membership pack. Total fitting time was around two and a half hours although i did stop to watch the F1 Racing
