Longer wheel studs
JC
Longer wheel studs
Post by JC »
Where's a place I can buy some locally?
Also looking for some tapered wheel nuts?
Any suggestions?
Thanks
JC
13T's, Greddy E-Manage, Greddy Profec E-01, RC 550's, 3SX fuel reg, Walbro, K&N, Tarox G88's and DS2500's all round, lowered, EGT probe, Intake temp probe, Nomad BOV, Short Shifter, Hella Upgrade, De-Cat, Powerflow Twin Exhaust, TechEdge Wideband Kit.
323ian
Post by 323ian »
JC have you looked at getting some good quality spacers that use the original studs to hold the spacer on and then the spacer has its own seperate studs which you bolt your wheel on to?
JC
Post by JC »
I really don't need to go that far, the ones that replace the studs come in at around +15mm offset, and I would sooner keep as close to stock as possible.
The front studs are slightly longer than the rears, so they will tranfer, thats the back end sorted, all I need do is find something for the front :grin:
JC
IWANT1
Post by IWANT1 »
Mitshubishi competition wheel studs +25mm longer stnd Item number: 300089784761
check this ad out on ebay
lee
shash1
Re: Longer wheel studs
Post by shash1 »
give westgate fastings on the gapton in yarmouth a look,they should be able to help you out
JC
Post by JC »
shash1 wrote:give westgate fastings on the gapton in yarmouth a look,they should be able to help you out
Tried Westgate, was in there on Friday, great with everything else...but not car specific like wheelstuds and wheelnuts etc.
JC
JC
Post by JC »
lee
Looks good, tried calling them but no answer... also tried SCA in Norwich today...bring it over they said, estimate a price of about 1.50 each, I also need to get a set (20) tapered wheel nuts in M12 x 1.5mm with a 17mm hex.
Good find, if SCA can't help, or are more expensive than they say then these guys look like they can supply :grin:
Thanks
JC
Ask for Matt or Kat and tell them that I said you should ask for a discount and then grin :D
Those two are well used to my bare faced cheek at knocking their prices down. Let us know how you get on.
323ian
Post by 323ian »
My wheel spacers with their own studs are 10mm.
Be warned that it could need the whole hub off the car to bang new studs in mate.
I put some in my old Mazda when i fitted Mitsi GTO brakes to it and was a right pain putting the new studs in.
stockcar
Post by stockcar »
we can normally help with this type of thing, do various gpN fitment studs and nuts, etc.......................
would imagine they are similiar spec to the EVO ones we do
ASPerformance
MOTUL & MILLERS OILS,
online shop!!
