Here's the spec -
Engine and Modifications
Standard O Series 1994cc 8 valve
Ford Sierra Cosworth 4x4 T3 60 trim turbocharger, fully rebuilt
17psi via -31 Actuator going up to 20psi.
Mildly flowed and rebuilt cylinder head to my own spec
RadTec full width full height alloy intercooler
Custom 3 core large capacity radiator
One off alloy catch tank
GK AutoWorks Mixture device and uprated carb needle
Flowed and reshaped inlet manifold
Apexi air filter
Rewired fuel pump
Magnecor KV85 Ignition leads
ERL Aquamist water injection running weak screenwash mix
Samco coolant hoses
NGK BPR6ES plugs gapped to 0.75mm
2.5 " exhaust from turbo back
3x5 Oval SS Powerflow backbox
Suspension and braking
Uprated/Lowered AVo 35mm springs with Monroe Gasmatic Shocks
Rear ARB removed (makes the back end less prone to lift off oversteer)
280mm Black diamond discs, EBC red stuff pads
Powerflex suspension bushes
Wheels
MGTF 15" 6 spoke alloys , 195/50/15 V rated Toyo Proxes T1-R rear 195/50/15 GY Eagle GSD3 Front
Bodywork
Smoothed and cut out front bumper with stainless steel mesh, rubbing strips removed, clear side repeaters
Smoothed rear bumper
Tinted rear lights.
Modified Front Grille to allow for extra cooling and filter intakes.
MG ZS boot badge fitted into grille
Bonnet louvres
Honda Accord wheelarch trims
MGRover chequered flags on front wings
Interior
AutoMeter boost gauge and EGT.
LED for W.I
Late spec Montego Centre console
JVC CD player
Otherwise standard
Last rolling road result = 200bhp corrected flywheel/220lb ft, 165 @ the wheels (@ 13psi, pre-mods 2003)
Approx 250/270+lb ft after current mods
AFR 11.5-1, EGT's at WOT in 5th 890 C (1675 F)
1/4 mile time with std turbo, intercooler etc = 14.545 (2.363 60ft)
Best terminal 97mph, @ 13.5psi boost Santa Pod October 2003
Current quarter mile time =
13.72@ 102.5 mph (2.22 60 ft) 15-16psi boost, Santa Pod 14/8/2005
Engine rebuild pics
Wire rung block and bored 20 thou oversize.
Engine bay before respray
After respray
Comparison between 45 and 60 trim Turbo's.
Engine fitted with new pistons
Built up engine
Engine refitted
Engine bay pic fitting RadTec intercooler.
As pictured for a small piece in Retro cars back in 2005.
After an Astra modified my back end when i was stationary at a roundabout in sept 2005.
Close up of the non-existant door gap.
The rebuild commences.
And the paint goes on -
Nearing completion
All done
And most recent pictures taken today -
