TLA's
TLA's
The whole tuning/modding world is littered with three letter ackronyns - here are a few to start the ball rolling
AFR : Air to Fuel Ratio
MAF : Mass Air Flow (how much air is going into the engine)
AFM : Airflow Meter
CAS : Crank Angle Sensor
TonyB
Post by TonyB »
ACT : Air Charge Temp (See MAT)
AFM : Airflow Meter
CHT : Cylinder Head Temp
EGT : Exhaust Gas Temp
MAP : Manifold Absolute Pressure (Air Pressure in the Inlet manifold)
MAT : Mass Air Temp (Temp of air in inlet Manifold)
I could do some more but I will let others have a shot :lol:
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
ONLY 370bhp & 405ft/lb @ fly
12.7s 1/4 @ 109mph in the wet
R.I.P.
AFM : Airflow Meter
EGB : Exhaust Back Pressure
PhatBob
Post by PhatBob »
AFM : Airflow Meter
BLD : Boarderline Detonation (Point of ignition timing where first signs of detonation occur)
CLT : Coolant Temp
IAT : Inlet Air Temp (See MAT)
LBT : Lean for Best Torque (Leanest air fuel mix for peak torque. For Gasoline 0.86Lambda (~12.5:1 AFR))
MBT : Minimum Best Torque (Earliest timing point where peak torque is produced)
WOT : Wide Open Throttle
