I reckon that could be it. Oh well I'm off to try out the HID light conversion I fitted this morning. (I couldn't wait for it to get dark, am I sad or what?)323ian wrote:Seems like you are just getting used to that new power then!
Rear end snaking
In the 32 for definitely - converting to MPH will mean that the ECU will be thinking in KM's .. eventhough the speedo is showing MPH, i.e. if you are doing 120 MPH - the ECU is thinking you are doing 70 MPH, thus respond differently.323ian wrote:
Ben can you explain a bit more about this conversion affecting the HICAS as i have not heard of this before?
On mine before I reverted to KMH, the steering stayed in light parking mode for sometime - now it becomes heavy almost immediately ... also with regards the Hicas - I've read articles of the car basically assisting in a crash by kicking the rear end out because of it receiving the wrong speed information.
