Race Harnesses
Race Harnesses
Got some 4 point harnesses arriving next week - sabelt clubman ones - are these legal for road use?
Just wondering whether I have to travel to events with normal belts in and then clip belts in on site.
ps - These are not going to be used all the time as they are a bit of a pain in the backside.
Also, any views of the safety of these when the car hasnt got a roll cage?
323ian
Post by 323ian »
They are legal as long as you use the original mounting points where the rear seat belts bolt onto the chassis of the car. I mounted the lap straps on mine to where the front seat bolts onto the car and it was fine. If you are running a rear strut brace and loop the rear straps over the brace then this becomes illegal. Hope this helps.
I am planning on replacing existing mounting bolts with eyelets (four rears) and the same for the existing drivers/pass mounting points. That way i should be able to clip in reasonably easily (for special occasion)
Not using a rear strut brace.... just front.
I have used eyebolts on my drivers side and that way I can keep the seatbelts as well. You need to make usre your have the typical seat belt release mechanism. As far as I know aircraft style release buckles are illegal as they will not pass an MOT.
Your seats will be prefectly safe with these and the feeling of being held securely is superb when pressing on. Just make sure you secure the harnesses to the rear at the most shallow angle possible (ie horizontal), lower than 45 degrees will cause problems but your seatbelt mounting points will be fine :)
I would suggest some decent harness pads for added comfort.
I think a roll cage would make me a bit more secure when I see how quick your's and dans cars are ...
You don't have a cage do you ? .. I can't remember seeing one ..
Belts have arrived:
as have:
now for fitting the little blighters :D
Well I think you just pull them over your hands ... as they look just like gloves to me ... :-D
rolty
Post by rolty »
Did you get one harness or two, Duncan?
two - would hate to be hit by a flying passenger :D
rolty
Post by rolty »
Wicked news matey :D
