strange goings on in transit
I dont know if this of at all of use but here are the fault codes for a transit.
http://www.autodiagnos.com/fileadmin/as ... rd_dtc.pdf
well finally the connect is dead , battery light fully on /slow wipers/dim lights etc.. etc..
managed to get it home but now the new battery is dead
i dont want to shell out on a new alternator to find its not that
i cant be arsed with it so i'l charge the battery and drop it off for someone to have a look
grrrrrrrrrrrrrr more bills
shane corsa
is it a connect? we have had a few come in at work and the little signal wire has rubbed through and broken thus thinking the alternators at fault, brings batt light on and wont charge. if i remember rightly the wire runs from the alternator along the back of the engine to the passengers side, may be worth a look?
shane
shane
Good work Shane
Yeah, pretty sure that Trev's vehicle of choice is indeed a Connect
On the plus, plus side I fitted the other 888's to Betty. They have less tread on them than a billiard ball but at least they're better than the ones I took off!!
Should be a laugh anyway....
About time you bought a man size Van buddy
WOOOOOOOOOOOO HOOOOOOOOOOO 15 mins and all fixed what a bloody relief
it was indeed a broken wire in the loom from alternator , wires run from alt to a plug on the rad which goes into main loom
cheers everyone for the help especially shane top bannana , i think lee also mentioned this problem early on in the thread so a common problem
CASE CLOSED ....
CASE CLOSED ....
