Tomorrow, there's re-position the PS reservoire and fill the rad. Oh, and bleed brakes after dumping ABS, re-piping and master cyl. change. And clutch to bleed and test.
Also see if it'll start and hope I haven't done anything terminal.
Wannadoos:
Breather tank.
Cold air feed
Impreza FMIC and Manifold mods.
Now that's the big question Gareth and at the moment, I don't know the answer. Maybe once the PAS is sorted everything will become clearer.RX7 wrote:Looking good work there Gerry !!
That Scoob engine looks as weird as my rotary one !!!!
Where is the cold air feed going to come from ?
Or not.
I found that thread a few minutes ago and didn't even spot the alternator :roll:duncan wrote:http://bbs.scoobynet.com/projects-40/50 ... ld-26.html
:thumb:
It's from a 3 cylinder daihatsu
I thought about going round the local motor factors and auto leccies but didn't have time. That alternator would fit under the throttle body with room to spare.
Thanks Dunk.
