200SX diff' rad and pipework
Found this today, forgot I had it! Was going to use it to cool the rear diff on my GTR. Could be used to cool the main box or transfer box. It will need the electrcal pump - from a scrapped 200SX S13 or buy one of the new ones below. Pump bracket included.
Link to web site:
http://www.r34gtr.piczo.com
Link to web site:
No problem. The bits came off my old S13 200SX. There is a rad', pipework and pump bracket for the
Link to web site:
Link to web site:
If you call Faye at Speedflow in Bristol, she should have a list of all the fitting used per cooling item. If not, I can tell you anyway.
The fittings and heat activated switches all came from Speedflow. The thermatic switches are set to 80'C and used via the +ve feed NOT the -ve (the pump bodies are earthed).
You will need 1 relay per pump or what I did was to use a caravan split charge relay supplied by Firstline in Dereham. You then get 2 relays for the 2 gear boxes plus all the wire you need!
Nik
Nik
Link to web site:
Link to web site:
