Does anyone know how to determine the year of manufacture of a Subaru EJ20 engine, a new engine was fitted to my car a few years ago, circa 2005 with low mileage (40,000 Kilometers) and I want to replace the L?H Rocker cover gasket to stop an oil leak so I need to establish the year of manufacture to ensure I get the correct gasket set
Thanks for any input
Harry
Engine Serial Numbers
Thanks Mike, I was a little concerned at it`s age as it was such low mileage when installed in the car, now I can get busy getting it repaired and hopefully do the car justice at Snettertonmikeb wrote:Harry that will give you the code for the engine that was in it jap engines don't come with any codes on them the engine was from a 95 if i remember correctly
i changed those gaskets before when i rebuilt it for mike s you just ask for the gasket for a 92 / 95
Hope that helps mike
Harry
