Hello,
What are the rules when it comes to on board filming during a track day? Are camcorders allowed?
Cheers
On Board Filming
- hoodedreeper
Sadly no suction mounts are allowed anymore
Something like this is ok though...
http://www.bigpower.co.uk/forum/showthread.php?t=18836
- hoodedreeper
As Jon and Harry said, the laws were tightened (get it!
) considerably in 2009-2010 regarding this. Have a look at the link provided and if you have any other queries about it, it's probably best to either PM Safety James on here (One of the team at Snetterton MSV) or call the circuit on 01953 887303
We will try it out on the 19th Chris.
- hoodedreeper
You can get the clamp variation of the suction mount now. You just need something such as a cage or harness bar to clamp it to.
http://www.b-hague.co.uk/superclamp_wit ... ad_sc2.htm
Mine fitted to the harness bar:
Yes pretty sure they are the same diameter. Shouldn't be difficult to rig something up. Daniel on here did some good work making some mountings.hoodedreeper wrote:The mount doesnt fit the cage as the cage is too big. Can you measure the Metro cage to see if its the same diameter? (would think they're roughly the same?)
Have you changed your seats Matt?M J P wrote:You can get the clamp variation of the suction mount now. You just need something such as a cage or harness bar to clamp it to.
