only got a few pictures as again the light in the workshops not very god for photo's but is great at keeping me warm and dry :-D
what the car will end up looking like but a bit lower and cleaner
a shot of the engine work being done changing the big ends and main bearings, front and rear crankshaft oil seals
a shot of the engine next to a CA18 to show that the RB is nearly as wide as the CA is long
engine and gearbox fitted
engine fitted to the car minus the rocker covers
and now a few of the engine and ancillaries fully fitted apart from radiator, power steering pump and reservoir (the air filters will be moved just temp fitted so could start car)
also managed to start car last Thursday after a bit of faffing around mainly my fault connecting the fuel delivery and return pipes wrong way round :roll: and could only let it idle for a few secs as now radiator fitted but sounded absolutely lovely just. Just got to fit radiator fill up coolant and make sure theres no leaks or bad noises coming from the engine then take it for a drive hopefully at the weekend, then onto an MOT (please pass) then to Gary's for a power fun
once i take it outside of the unit will get some pictures of the interior and some more up to date pictures of the exterior(after a wash)
Lee.
