well the new wheels are on and looking sexy also checked for scrubbing as i dont like scrubbers
the rears are 100% fine even with my brother jumping in the boot
And the front clear fine when the car is jacked up.
When on the floor, they clear.
The front of the tyre misses the chassis leg fine but the back is kinda close possibly cardboard thickness maybe a touch thicker but for a mot they will be fine.
Down the road with the tyre flexing i recon it may scrub slightly nothing some 10mm spacers and longer bolts cant fix i'm sure
Also fitted some new number plates to make it look even better
The smoking issue is the only thing concerning me now!
If the car doesn't stop smoking when going down the road I'll have to abandon the mot
But my suspicions are that the smoking is being caused by 2 things,
1 being a knackered turbo oil seal much like my 200 and
2 being the old oil which had water mixed in getting past the rings and being burnt off making it seem worse.
The smoking went away when left to idle at 2000 rpm for 15 minutes like the flush asked for, which gives me the idea its the turbo oil seal
Fingers crossed i'm right or i need to change the heads over and get a new turbo sooner than i thought
