No. he is getting 24 bangs per revolution due to split timing. I will fix the link. Its the equivilent of a 12 cylinder engine.
Scott
RX7, sub 10 qtr... No turbo, No charger, No gas.. Mental!!
theres only one phrase to sum that up then, and that is "fuck me!"
in my limited experience, i had always thought 2-stroke engines made the best power, but thats just been blown out of the water by these wankel rotaries!
edit: in my defence, i did say it was a quick 60 seconds research
12A = 1146cc = 69.9 cu in (small 2 rotor)
13B = 1308cc = 79.8 cu in ( 13B 2 rotor ie fd3s rx7 )
20B = 1962cc = 119.7 cu in ( cosmo 3 rotor )
26B = 2616cc = 159.7 cu in ( 4 rotor ie leman mazda 787b)
Perspective....
308 cu in V8 = 5047cc
What people/enthusiasts/engineers/governing bodies etc get so confused about is that they try to rate the Wankel on a two stroke cycle or on a 4 stroke cycle and not on a Wankel cycle.
It can conform to any of the above so long as you have a basic understanding of time line events.
13B as follows
at 360deg (2 stroke)
=1308cc
at 720deg (4 stroke)
=2616cc
at 1080deg (Wankel)
=3924cc
The last one is the only correct one, none of the others are right because the engine has not completed anything,
So multiply mazda figure by 2 as they rate it as a 4 stroke engine ie
12 A = 2292cc
13 B = 2616cc
20 B = 3924cc
26 B = 5232cc
Perspective....
13B as follows
=1308cc
=2616cc
at 1080deg (Wankel)
=3924cc
12 A = 2292cc
13 B = 2616cc
20 B = 3924cc
26 B = 5232cc
As promised
example
#. driver/user name- type (rx7 s6) engine type (20btt 20b 3rotor turbo )
Tubbed
1. TUF-13B - RX7 S6 20btt...........................7.26 @ 188mph (W.S.I.D)
2. dysonc - RX7 S4 20bt..............................7.45 @ 174mph (Willowbank)
3. bullish - RX7 S6 13bt...............................7.85 @ 165mph (Willowbank)
4. NUT003 - RX3 13bt.................................8.03 @ 166mph (Willowbank)
5. YGO20B - RX7 S5 13bt............................8.07 @ 171mph (W.S.I.D)
6. AVENGE - Datsun 1200 13btt.................8.15 @ 164mph (W.S.I.D)
7. Buznuts - RX7 S6 13btt...........................8.18 @ 164mph (A.I.R)
8. Buznuts - Cougar 13bt............................8.33 @ 163 mph (A.I.R)
9. TUF-13B - R100 13bt...............................8.40 @ 158mph (W.S.I.D)
10. ozmodgrant - 1200 sedan 13bt............8.55 @ 152mph (Willowbank)
11. Mazdat - "ROMPER" RX3 20bt................8.71 @ 154mph (W.S.I.D)
12. ChookRX - RX4 20bt..............................8.997 @ ---mph (A.I.R)
13. RAPID3 - RX3 20bt.................................9.155 @ 134mph (A.I.R)
14. GRUMPE - RX2 13bt................................9.38 @ 148mph (EC)
Untubbed
1. GRUMP2 - RX2 20bt................................8.20 @ 164mph (W.S.I.D)
2. GoldCoupe - RX2 12at............................8.77 @ 153mph (Willowbank)
3. RXENG - "DRAGME" RX3 13bt..................8.78 @ 152mph (W.S.I.D)
4. 13BEE - RX3 13bt...................................8.82 @ 150mph (Willowbank)
5. ozmodgrant - 1200 ute 13bt..................8.87 @ 157mph (Willowbank)
6. PRO20B - RX4 20bt................................9.11 @ 149mph (W.S.I.D)
7. Critta - RX3 13bt....................................9.15 @ 150mph (W.S.I.D)
8. big 20b - RX7 S2 20bt............................9.1 @ 151mph (Kiwana)
9. JETRX - "MERCY" RX3 13bt .....................9.30 @ 148mph (Calder)
10. AVENGE - "SUB11S" RX4 13bt...............9.36 @ 143mph (W.S.I.D)
11. YGO20B - RX7 S5 13bt...........................9.37 @ 136mph (W.S.I.D)
12. MRHELI - 1200 ute 13bt.......................9.48 @ 142mph (W.S.I.D)
13. loco - RX2 20bt......................................9.50 @ 139mph (Willowbank)
14. projectx - 323 13bt...............................9.53 @ 141mph (E.C)
15. RX3ROTOR - RX3 20bt..........................9.55 @ 146mph (Willowbank)
16. TRBO7 - RX7 S3 13bt............................9.60 @ 145mph (Willowbank)
17. XSPSI - Gemini 13bt..............................9.68 @ 138mph (Calder)
18. GRIMAS - KE20 13bt..............................9.78 @ 138mph (W.S.I.D)
19. REDYRX - RX4 13bt................................9.79 @ 141mph (Calder)
20. 7 SINS - RX7 S2 13bt.............................9.80 @ 144mph (W.S.I.D)
21. 12ENV - RX3 13bt..................................9.8 @ 147mph (Willowbank)
22. 15EEU - RX7 S6 13bt.............................9.87 @ 143mph (Willowbank)
23. OFGUTZ - RX3 13bt...............................9.91 @ 136mph (W.S.I.D)
23. SHARK - RX7 S3 13bt............................9.91 @ 136mph (Willowbank)
24. ComZilla - RX7 S2 13bt.........................9.9 @ 137mph (W.S.I.D)
25. A777 - RX7 S3 13bt...............................9.99 @ 136mph (Willowbank)
26. jet7 - RX7 S3 13bt...............................10.14 @ 135mph (W.S.I.D)
27. PSI:100 - R100 13bt............................10.16 @ 133mph (Willowbank)
28. DUZ69Z - RX7 S3 13bt.........................10.17 @ 133mph (W.S.I.D)
29. freknu1 - RX7 S3 13bt .........................10.20 @ 139mph (Calder)
30. BOOsted7 - RX7 S3 12at......................10.21 @ 137mph (Heathcote)
31. OIM:666 - RX7 S2 13bt.........................10.28 @ 134mph (Willowbank)
32. AJC13B - RX7 S3 13bt..........................10.32 @ 133mph (Heathcote)
33. MOE-13B - RX7 13bt.............................10.32 @ 133mph (W.S.I.D)
34. CTHIS - RX7 S6 13bt.............................10.43 @ 131mph (Willowbank)
35. sir03 - RX3 13bt....................................10.43 @ 131mph (Willowbank)
36. SPASTK - RX2 13bt................................10.46 @ 132mph (Heathcote)
37. NFS13B - MX5 13bt...............................10.48 @ 128mph (W.S.I.D, radials, pump fuel)
38. 20b_boi - 626 20bt................................10.50 @ 136mph (A.I.R)
39. TWN55 - RX4 13btt................................10.57 @ 133mph (Willowbank)
40. OKE020 - KE20 13bt..............................10.6 @ 129mph (Willowbank, slicks)
41. YES10S - RX2 13bt................................10.6 @ 127mph (W.S.I.D, slicks, pump fuel)
41. MAZ13B- RX3 13bt.................................10.6 @ 127mph (W.S.I.D, slicks)
42. HiRPM - R100 13bt.................................10.71 @ 125mph (A.I.R)
43. 00H808 - 808 13bt bp...........................10.73 @ 127mph (Willowbank, street tyres, pump fuel)
44. glenn - RX7 s4 13bt...............................10.75 @ 129mph (A.I.R)
45. [ MADRX2 ] - RX2 13bt .........................10.75 @ 128mph (Calder)
46. rx313bta45 - RX3 13bt.........................10.7 @ 126mph (Heathcote)
47. KPA323 - 323 12AT...............................10.8 @ 122mph (W.S.I.D, street tyres)
48. 31LLR - RX3 13bt.................................10.89 @ 133mph (Willowbank)
49. R100 - RX3 13bt...................................10.8 @ 90mph (Willowbank)
50. FDRACER - RX7 S6 13bt.......................10.9 @ 138mph (A.I.R)
51. RXTHREE - RX3 13bt.............................10.9 @ 128mph (Kwinana)
52. Mundi - RX7 S3 13bt.............................10.92 @ 128mph (W.S.I.D)
53. 10sec_rx7 - RX7 S2 13bt......................10.94 @ 125mph (EC)
example
Tubbed
Untubbed
- jungle-jim
I think the rotary lives on in steam engines now. There is a company that make a rotary go kart engine ( AR50 )
I think mazda mostly own the rights to the rotary engine. The problem with rotaries is the efficency due to the irregular shaped combustion chamber. This leads to the engine requiring more fuel ( BSFC 0.62 ) also creating lots of hydrocarbons due to this and needing oil injection to lube the rotor housings.
Scott
Scott
