Got the door bushings fitted. The doors definately have that nicer shut noise,but on the odd occasion they need a firmer push to shut them. I guess in time they'll wear abit and it wont happen so much.
Over the past week or so i've been busy making more DIY parts for the car. I first started with another sheet of Dibond and made the front splitter,followed by some front Canards out of some thin aluminium (it may be too thin,but will see how i get on)
I decided to curve the splitter into the corners of the bumper rather than having it the same width all the way around. Made some brackets from some 25x2mm steel plate and mounted to where the OEM undertray bolts to (i used the front stud).
I originally left the centre of the splitter and used the two threaded parts on the bottom of the intercooler to mount it,but this pulled the splitter down leaving a gap underneath the bumper. So i cut the a section out of the middle so the intercooler fit snug-ish and made some brackets (will need to re-do them at some point as they're not the prettiest). Lastly i used a couple of adjustable turnbuckle rods for the centre.
I have noticed the splitter has pulled over to the passenger side since re-fitting the bumper. I'll get it up on a ramp and see if i can pull it across. It was a very very snug fit fitting the bumper back on,hopefully theres enough give in the brackets (once slackened off) to move it back across.
Next was fitting some tension cables to the wing stands. I used some 4mm wire cable with some 6mm clamps and eyelet bolts. Its definitely made a difference,its not swaying from side to side as i'm driving now
I haven't had the chance to drive it 'properly' yet due to all the rain we've had recently. From what i have driven it,it does feel more stable and the front hasnt gotten much lift (from what i can tell)
After taking the above photos,i notice how badly i need to adjust the suspension,another thing on my to-do list
