Our sump has a standard baffle plate in it but am thinking that we might need to upgrade the engine oil protection set up. So the options are to use the spare sump and have additional baffles welded/fabricated. Have the sump converted to a big wing sump or install an Accusump kit.
What are peoples views on the choices I've listed and has anyone any experience with Accusumps. Also what's the basic difference between a manual system and an electric system.
Big wing sump or Accsump
Re: Big wing sump or Accsump
Big wing sump. Proven to work well on cosworths I had a gated baffle plate fitted at the same time
Thanks Ian. Where did you get yours done if you don't mind me asking.
