TNTRacing - XRCosworth
Re: TNTRacing - XRCosworth
I wanted to call her "the black widow maker"
Can't believe it's the same car!
It may be Christmas but the work doesn't stop. Well not for Alan. I've been ill so not seen Alan since before his Daughter was born. Inspite of that Alan has been busy, very busy.
Graphics removed
Exhaust heat wrapped replaced
Wastegate plumped up
Power steering pipe replaced (had tiny leak when going lock to lock stationary)
Foam to passenger seat changed
Rollcage painted in places missed
Small hole in floor welded
Well done mate and again sorry I was not around
Graphics removed
Nearly forgot, he also
Fitted new discs and pads
Changed the anti sway bar drop links
To the Explorer
To the Explorer
Starting to feel a little excited and nervous at the same time as the parts start to arrive. Trailers booked, time off work booked. We've even finally got a plan together for the spare gearbox
managed to get some parts for our trip over to the governor to sort the old girl out.
got a new BD15 inlet cam to be fitted
also got some steel adjustable verniers, heard some bad things about alloy ones for the
cosworth so I was determined to find some steel, took couple months but found a pair local.
also this is my little one in her other cosworth baby grow in pink.
REALLY looking forward to going over to APT on the 18th feb 4am start
looking forward to getting you guys back on track
Cheers Gary. I've just to get a new cambelt and tensioner, seeing as this one will have to come off to sort the cams we thought we might as well fit a new one.
When are you guys at APT?
