Cleaning the engine bay is always an enjoyable part of the job, and especially when it is something as rare as this. I always make a point of checking the bay carefully before I start spraying chemicals and water around, and follow a 'less is more' approach to save having any problems later on. The underside of the alloy bonnet needed cleaning too, so it was the inner wing liners, bonnet underside, rocker covers and anything else I could safely rinse and clean
<a href="
http://www.flickr.com/photos/93963817@N07/9808228464/" title="2013-09-18 09.38.35 by Stuart Staples, on Flickr"><img src="
http://farm6.staticflickr.com/5491/9808 ... e19b_c.jpg" width="800" height="478" alt="2013-09-18 09.38.35"></a>
Alloys were next, and these 22" monsters were beautiful to clean as they allowed easy access to the rears and the calipers too!
Before
<a href="
http://www.flickr.com/photos/93963817@N07/9808292153/" title="2013-09-18 09.41.39 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7452/9808 ... 64d9_c.jpg" width="478" height="800" alt="2013-09-18 09.41.39"></a>
After
<a href="
http://www.flickr.com/photos/93963817@N07/9808218714/" title="2013-09-18 10.04.32 by Stuart Staples, on Flickr"><img src="
http://farm4.staticflickr.com/3792/9808 ... b4ab_c.jpg" width="800" height="478" alt="2013-09-18 10.04.32"></a>
<a href="
http://www.flickr.com/photos/93963817@N07/9808235896/" title="2013-09-18 10.04.40 by Stuart Staples, on Flickr"><img src="
http://farm4.staticflickr.com/3745/9808 ... 70a8_c.jpg" width="478" height="800" alt="2013-09-18 10.04.40"></a>
Rears were next with the same process applied
<a href="
http://www.flickr.com/photos/93963817@N07/9808209285/" title="2013-09-18 10.04.50 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7350/9808 ... a122_c.jpg" width="800" height="478" alt="2013-09-18 10.04.50"></a>
My wheel and arch armoury!
<a href="
http://www.flickr.com/photos/93963817@N07/9808125616/" title="2013-09-18 10.08.38 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7318/9808 ... 92c7_c.jpg" width="800" height="478" alt="2013-09-18 10.08.38"></a>
A soft brush for the face of the alloys, a long reach brush for the arches, two long reach brushes for the alloys themselves and another different brush for the tyres with a separate wash mitt for the rear of the alloy spokes..........and a bucket that is only ever used on alloys!
A close up of a 8 pot caliper after cleaning
<a href="
http://www.flickr.com/photos/93963817@N07/9808226386/" title="2013-09-18 10.24.55 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7299/9808 ... 2fd1_c.jpg" width="800" height="478" alt="2013-09-18 10.24.55"></a>
With the alloys, tyres and arches cleaned it was time to loosen the dirt that was on the car before the two bucket was method started.....on with my mix of snowfoam and all purpose cleaner
<a href="
http://www.flickr.com/photos/93963817@N07/9808200195/" title="2013-09-18 10.54.43 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7362/9808 ... 01bc_c.jpg" width="800" height="478" alt="2013-09-18 10.54.43"></a>
This is applied via a pump sprayer as it makes less mess and also means I have greater control as to where it goes on the car.
With the car washed top to bottom using a two bucket method it was gently dried using my uber soft yellow towels and it was time to start some polishing combinations, to see what would remove the swirls and improve the paint depth and gloss. These photos make the paint look worse as the reflection of the car-ports walls gives the impression of paint surface irregularities. If you focus on the light reflections instead and the hazy finish in the first photo, that will give you a better idea of the improvement
Before
<a href="
http://www.flickr.com/photos/93963817@N07/9808195875/" title="2013-09-18 12.40.43 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7292/9808 ... 6cd2_c.jpg" width="478" height="800" alt="2013-09-18 12.40.43"></a>
After using Autosmart Evo 1 on a medium abrasive pad
<a href="
http://www.flickr.com/photos/93963817@N07/9808198754/" title="2013-09-18 12.48.34 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7409/9808 ... 5486_c.jpg" width="478" height="800" alt="2013-09-18 12.48.34"></a>
This finish was further improved with the use of Poorboy's hand glaze prior to the sealant, but more on this later
Polishing complete
<a href="
http://www.flickr.com/photos/93963817@N07/9808261793/" title="2013-09-18 14.05.04 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7434/9808 ... 6ee4_c.jpg" width="800" height="478" alt="2013-09-18 14.05.04"></a>
Chuffed with the depth and clarity of the reflection
<a href="
http://www.flickr.com/photos/93963817@N07/9808210496/" title="2013-09-18 14.22.07 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7325/9808 ... b77b_c.jpg" width="800" height="478" alt="2013-09-18 14.22.07"></a>
This is the offside front wing after polishing (refer to the first batch of photos to see the before picture)
<a href="
http://www.flickr.com/photos/93963817@N07/9808167513/" title="2013-09-18 14.22.19 by Stuart Staples, on Flickr"><img src="
http://farm8.staticflickr.com/7359/9808 ... 4b98_c.jpg" width="800" height="478" alt="2013-09-18 14.22.19"></a>
Underside of bonnet after polishing
<a href="
http://www.flickr.com/photos/93963817@N07/9808182995/" title="2013-09-18 14.42.12 by Stuart Staples, on Flickr"><img src="
http://farm3.staticflickr.com/2883/9808 ... 8396_c.jpg" width="800" height="478" alt="2013-09-18 14.42.12"></a>
Engine bay and surrounds completed
<a href="
http://www.flickr.com/photos/93963817@N07/9808205026/" title="2013-09-18 14.42.21 by Stuart Staples, on Flickr"><img src="
http://farm4.staticflickr.com/3811/9808 ... 6468_c.jpg" width="800" height="478" alt="2013-09-18 14.42.21"></a>
Sealant curing
<a href="
http://www.flickr.com/photos/93963817@N07/9808141165/" title="2013-09-18 15.34.10 by Stuart Staples, on Flickr"><img src="
http://farm4.staticflickr.com/3790/9808 ... 1338_c.jpg" width="800" height="478" alt="2013-09-18 15.34.10"></a>
Finished photos up next
