Hi, I took the evo for its mot this morning. It's been off the road for two years now due to financial reasons. So it's first one for nearly 3 years!. All went well except the emissions which where incredibly high at 5.46 percent CO!
What could be making them so high? Any ideas?
It's got fresh fuel in, I drained all the old out. Gave it a good 10 mile hard drive on the way to the test centre.
It seems to smell like the cat isn't working well. Could the cat have gone from being sat up for 2 years?
Cheers, pete.
Emissions well out = fail mot help please
das ist kaput!
1994 Mitsubishi lancer evo2 gsr IN BITS AGAIN
1988 Toyota mr2 1.6
1997 540i v8
1988 Toyota mr2 1.6
1997 540i v8
If the lambda constantly reads lean the ecu will dump in more fuel afaikpedGSR wrote:Or could it be the lambda sensor? Using a voltmeter it don't appear to be switching. Could it put the emissions out that far though?
It should be flicking back and forwards between 0-1 volt if it's the standard narrow band sensor
