Pete's Camaro
Monster
Post by Monster »
Skills fabricating that lot Pete, looks great too. You should really notice the new set up on track. Worthwhile mods
pjs65
Post by pjs65 »
Thanks for the comments , iam trying to do a good job with these as i don't want anymore black flags for smoking brakes .
I have not spent to much on this as i wasn't sure if the parts would fit but at a guess and including the bias bar stuff i would say about
pjs65
Post by pjs65 »
Iam still plugging away at getting the brakes finished and i reckon 2 more weekends should see the job done . I haven't booked any TD's so its all been a bit slow going with nothing to get a move on for , i didn't want to rush the brakes as they are not something you can take chances with .
I brought some new halfshafts and bearings as the old one's were worn and the oil seals leaked abit , i also think that the shafts weren,t totally straight . I ordered some OE spec one's as iam not running huge power and unlikely to be in the near future:frown: . I thought that they would be a straight swop being OE but they were 3mm shorter than the old one's "f*ck", you'd think they would be spot on as they've been making them since the 60's . 3mm out with drum brakes might be ok but with disc's not really , so i had to remove the brake backing plate and rebend and skim it 3mm. It went back together ok and is all finished apart from bleeding the calipers , i also replaced all the pipe from the front to back and turn up some locating rings for the hubs .
I now have a proper handbrake with one i can reach and that works :hurray:, real pleased about this as i wont get moaned at by the MOT guy for having a useless parking brake . Iam use to old english cars so having a dodgy handbrake is nothing new but the contraption that chevy came up with is real stone age stuff .
I got an E39 handbrake off Ebay for a tenner and a pair of new cables for
Great work Pete:thumbs: What were they smoking when they came up with that excuse of a handbrake:willy_nilly:
john B
Post by john B »
Great stuff Pete I know what you mean about the stupid parking brakes on Yank cars I had to replace the cables on my Trans am years ago I could have re fenced my garden with the amount of cable they used....
Hopefully you will have it all ready for Modified live then ?
pjs65
Post by pjs65 »
pablo wrote:Great work Pete:thumbs: What were they smoking when they came up with that excuse of a handbrake:willy_nilly:
I don't know about drugs but i think they might have had a liquid lunch and left the trainee to finish the job off .
john B wrote:Great stuff Pete I know what you mean about the stupid parking brakes on Yank cars I had to replace the cables on my Trans am years ago I could have re fenced my garden with the amount of cable they used....
When i got the Camaro it was a shell with all the bits in boxes and i was never to sure that i had put the parking brake together properly , but as you know that's how they are .
I will try and make the Snetterton event but i haven't put my name down because i wasn't sure i would finish the car in time .
I have put a new module into the dizzy and that will be all i do to the engine this year . The standard HEI dizzy has a rather wimpy module as they were only ment for low powered emission regulated smog motors . Its got a higher output coil but needed a better module to go with it . The modules are like the Honda ones as they are known to fail sometimes , so i will keep the old one in the glovebox as a spare .
The top one is the new part and is about half the size of a matchbox , this should provide sparks to 7k+ not that the motor gets to the sunny side of 6k anyway
This is it fitted into the dizzy
Nice work pete! Fingers crossed you do it finished before the modified nationals. Our club area wont look right without the mighty camaro to balance out the jap stuff.:thumbs:
pjs65
Post by pjs65 »
I didn't get to go to ML @ Snetterton because of a faulty master cylinder and also because of my own stupidity . I had spent the last 2 weeks finishing the brakes and had finally got to bleeding the system , doing the rear cylinder and calipers went well but i had trouble with the front . The front wouldn't bleed properly and also the cylinder kept getting stuck , but instead of junking it i carried on trying to get it to work . That was my stupid mistake because a brief test drive proved that the cylinder was junk and that i had poor brakes , so back into the garage and pulled everything apart and started again . I removed the cylinders the calipers and some pipework that i wasn't happy with and also the disc's , basically everything got taken off .
I put it all back together carefully and used feeler gauges and verniers to get the caliper brackets square before refiiting , i bled the master cylinders before bolting on and replaced the bad master cylinder . Everything got checked and measured before being put back on , took a day to do but i should have took more care in the first place:iamwithstupid:
Time for another test drive which started off a bit tentative but i soon gained some confidence in the car and was alot happier with the brakes . I still have too much pedal travel which is down to the front .625 cylinder being too small so that's getting changed for a .70 , that should also make the rears work a bit more as they aren't doing as much as they should . But generally with some tinkering and changing the OE pads for track pads i think the brakes should be fine and ready for a track session :thumbs:.
Whilst on my little test drive i noticed that the motor seemed to run really good , it tends to splutter about town and doesn't like traffic . It was almost splutter free and on the way back i was having to resist putting my foot down . I had replaced the ignition module with a better one and did a minor jetting change , but wow what a difference as the torque that left last year has returned and with just a little bit of throttle coming out of a roundabout got the wheels spinning up . Usually a slow corner in 2nd gear would be accompanied by a stutter before the engine did anything worthwhile but a big surprise there and a big grin, it stops and it goes :hurray:.Pete
john B
Post by john B »
Great news pete well done I bet you can't wait to get her out on rack now then.
pjs65
Post by pjs65 »
john B wrote:Great news pete well done I bet you can't wait to get her out on rack now then.
Yes iam looking forward to using the car properly and i need to do some trips and TD's.
I have changed the .625 front master cylinder to a .70 and that has improved the braking loads , initial bite is nearly as good as with the servo but with far less pedal travel . I have also slightly increased the pedal ratio to 6.25 up from 6 because iam using the bigger front cylinder and so far all the little adjustment have worked . I put Yellowstuff pads on all four corners and i know not everyone here might do that but i spoke to a guy who used them on a corvette and he liked them . The Corvette is going to be similar handling and grip to the Camaro well more so than 4x4 turbo jap cars or front wheel drive euro stuff , so i went with what the Corvette guy used .
Since switching to the manual box i haven't been getting any engine braking when i back off the throttle and also the engine sometimes ticks over quicker . I guessed that something was sticking in the throttle linkage to the carb but with a bigger return spring and the throttle linkage moving freely i couldn't see why . The only other thing was to remove the carb and check that the butterflies were seating ok , and they weren't so i reset them and i now have a stable tick over and engine braking:hurray:
Still with the carb i could never get the idle adjusted to how i wanted and having done some research i found that the idle circuit could be rich . The idle jets on the carb are a fixed size and not changable and the only way i could weaken it was to put a piece of wire onto the jet . This is really low tech and crude but i couldn't think of another way to do it , if it didn't work i can also remove the wire . Amazingly it did and the engine ticks over way better than it ever did and when i turn the idle mixture screws they actually work , the idle jets must have been way to big . After 5 years iam finally getting the hang of the carb although a dyno session is what it really needs .
Picture time , front brakes with Yellowstuff pads
