I've done some more analysis of this. I have used 888s myself in my Lotus Elise and they are the tyres that the Mk2 MR2 use. They would be the better comparison as they are close to 1200kgs (with driver), My Lotus was about 940 with driver.Monster wrote: Also interesting on the cornering G info - the Khumos feel to me to be as good as the 888s but from what you were saying I think I'll give Mich pilot Sport Cups a go next (now actually as n/s rear khumo is ready for the bin)
There is a table of analysis below which I think on here you have to click on to view.
http://www.roflsaurus.com/users/Maxx/rolf-888grip.jpg
To explain these are stats from the RT Analysis Software, we are looking at Min and Max lateral G (left/right cornering), we look at 98% max/min to cut out the peaks and the full max/min where you can sometimes get peaks if you hit a curb of something.
I do remember seeing 1.3g on 888s and you can see that Christian gets that as well although you have to take into account spread as the g readings are based on the DL1s mounting and sometimes you cant get it totally flat, especially if it's a temp installation like I had in Christians (and in fact the Elise).
The spread is the difference between max/min, if you divide that by 2 you get the real which is really the amount if lateral g the car was able to pull.
If you look at the table the RED numbers are the ones to look at. As can be seen, for 98% Christians Kumhos are pretty much the same as the 888s but on peaks they are much further behind. Not too surprising as the peaks are probably turn-ins and of course the Lotus is going to be great on turn-in, the MR2 pretty good but the extra weight and front engine layout would restrict this on the GTR32. I also think setup would help a lot here, the car was not very sharp on turn-in, I slacked off 2 clicks of bump at the front to help and thought this was a very slight help but it's more a camber and overall stiffness issue.
I do have data from CSLs on Pilot Sports and GT3 Porsches but all on external HDDs so prob wont get to lookiing at that for sometime but from memory they are better, as a rule of thumbs I 'rate' 888s as 1.3g tyres and Pilots as 1.4g tyres, these are just very general guidelines.
Malc
