Mr Fletcher wrote:ok a few questions if i may please ;
- do i need a fmic for sprinting if so are the ones on ebay any good?
- can i fit 4 pots under the 16" rims?
- where can i get "unbranded" black silcon hoses from ?
- are cheap coilovers any benefit rather than standard suspension?
- best place to get a new fuel pump from ?
With all the best intentions this will not be used sympatheticaly:)
a) 'Need'? No. 'Want' maybe
I know of plenty of guys that use cheap ones like Autobahn and they work well enough even if the fitting is a bit shonky sometimes
b) Yes
c) Pirtek
d) Adjustable in terms of height and stiffer spring rates
e) Walbro 255
I should stick to cleaning really
