Fuel Pressure test query
Guys,
If you have put in new fuel lines, injectors /rail, FPR etc, would you pressure test it first before bolting the rails up properly ?
At the moment I have no battery but can try and connect the old one up to do it. Have no coolant, oil etc so wont turn the car over but I know you can short some of the fuses to make the fuel pump run.
Probably gives me a chance to set the base pressure with the FPR too.
Do you guys do this before bolting everything in place properly ?
tomcat
Post by tomcat »
RX7 wrote:Guys,
you should be able to remove the fuel pump relay and short out the 2 switch terminals to run the pump
its usually terminals 30 and 87 but you'd need to check this
scott
