Interesting point about the spoiler. I think most of the stuff 'we' use in terms of spoilers is pretty ineffective really, and has a bigger effect on the mind than it does on the car
(I accept that if you are looking at full aero packages with flat floors, mega-low ride heights etc then it may be different but that's another post and another discussion
Rob, what sort of suspension settings are you using? Your camber settings looks really neutral, front and back, and I'm interested to see whether it's just how the photos have come out or whether you run the car like this. I'm guessing you haven't had any issues on the track or you have a solution in mind.
Gareth; this front mount thing........I'm not sure Rob's mentioned that he's having any intake temperature issues although I appreciate that this may be of greater significance when boost goes up
You could always drill the front bumper out for greater airflow if needs be mate, and that way you can retain the stock-ish profile for maximum stealth (as you're weaving lock to lock down the road with over 400bhp
The more I look at this the more I like it
You don't see many S14's running Ganador mirrors either. Nice
