The time has come where the important parts are turning up its like christmas time all over again
Flywheel skimmed
Crank polished up within standard spec
Crank back in its rightful place torqued down to a lovely 65nm with all new bolts
Liners pistons and rods all back in held in place to stop the liner seals getting damaged when being moved about
Big ends all torqued down to 45nm, oil pump stripped cleaned greased inside for the first start up
Fingers crossed the head, piper cam and vernier pulley turn up before the weekend so i can put the cam in then get the sump and covers back on ready for being put back in the car.
Things are finally getting a move on
