The pocket rocket
Adam_sx
Post by Adam_sx »
i was looking for a 2ltr turbo conversion i had seen forsale but its been sold :( so im sticking with the fragile engine for now
Rob S wrote:That's the TNT syndrome in effect!
:smilielol5:
I seem to remember back in the day that people modified the 1.7 lump out of the 21s (Also used in the mk2 5 Monacco edition) with the turbo and gubbins from the GT. That would be stronger surely? (Albeit like rocking horse poo)
Adam_sx
Post by Adam_sx »
sounds like alot of effort rob, plus my new liner/piston set and other gubbins have already turned up so its staying 1.4 for now
crank goes in for machining tomorrow then hopefully pick that and the long list of parts from renault the following saturday
the head is going to slow me down the turn around time is looking about 3 weeks atm :(
Just in time for the rolling road, good effort ;)
Adam_sx
Post by Adam_sx »
block is painted a lovely black and looking sexy. I will get some decent photos using the slr this time
Took the crank, rods, liners/pistons and flywheel down to the machine shop this morning. Going to Polish the crank/grind if needed, fit the rods to the pistons, skim the flywheel and quite possibly have it all balanced up with the clutch cover etc.
The shop recon they might be able to source me some acl bearings which if they can get them i'll be using them otherwise i'll stick with renault bearings something with some quality that lasts.
Pretty much laid down the rule of... no more cheap shit that lasts 5 minutes on this engine now... it will not go bang again! fingers crossed
Adam_sx
Post by Adam_sx »
Few pictures bit out of date tho, block is prep'd all threads chased and repaired where needed and block painted in satin/radiator ht aerosol paint
Good bye nasty red flakey paint
Goodies from CGB, rods, chain, tensioner, gasket, water pump bolts, uprated fuel pump liners, pistons
Then my order from renault came in, Mostly bolts, nuts, gaskets and a new rocker cover as mine had been crushed and wouldnt seal properly
Mmmmmmmmmmm, shiny bits.
Looking good Adam:)
pjs65
Post by pjs65 »
Theres nothing like getting a box of new shiny bits . Pete:Chevy_anim:
Awesome, nice work fella.
